Transformer User Data Sheet
发表于:2026-9-19 12:17:04|本帖共 741 字 2878
       Thanks for choosing and consulting our products!Please provide following information
  变压器型号(Transformer type):
  噪声水平(Noise level): dB
  额定容量(Rating power): KVA
  开关要求(Tap-changer requirement):
  相数(Phase number):
  套管Bushing
  高压套管H.V 低压套管L.V
  频率(Frequency): Hz
  额定高压(Rated high-voltage): kV
  气体继电器(Gas relay device):
  分接范围(Tapping):± ×  %
  压力释放阀(Pressure relay device):
  额定低压(Rated low-voltage): kV
  互感器CT:
  绝缘水平(Insulation level):LI AC /LI AC
  控制箱(Control box):
  联接组别(Connecting symbol):
  油面温控器(Top oil temperature indicator):
  阻抗电压Uk(Impedance): %
  绕组温控器(Winding temperature indicator):
  使用条件(Service condition):
  海拔高度(Elevation): m
  环境温度(Ambient temperature): ℃
  其他需求(Others requirements):
  冷却方式(Cooling):
  绝缘等级(Insulation grade):
  空载损耗Po(No-load loss): KW
  负载损耗Pk(Load loss): KW
  绕组温升(Winding temperature rise): K
  油面温升(Top oil temperature rise): K
