Are you putting the right fiber for the right purpose in your concrete?
发表于:2026-9-15 12:22:35|本帖共 1,365 字 1219
  Introduction
  Understanding Microfibers vs. MacrofibersMicrofibers, typically with diameters under 0.3mm, are designed to mitigate early-stage plastic shrinkage cracks. These cracks occur when concrete loses moisture before setting. By uniformly dispersing throughout the mix, microfibers create a network that holds the concrete together, reducing crack width and frequency. They are ideal for non-structural applications like residential slabs, pavements, and decorative concrete.In contrast, macrofibers (diameter ≥0.3mm) serve as secondary or even primary reinforcement in some cases. They enhance toughness, impact resistance, and control both plastic and drying shrinkage cracks. Macrofibers are suitable for heavy-duty applications such as industrial floors, tunnel linings, and precast panels.Selecting the Right Fiber for Your Project1. Assess Project Requirements
  2. Dosage MattersUnder-dosing fibers can lead to inadequate performance, while over-dosing may cause workability issues. Refer to the table below for general guidelines:ApplicationFiber TypeRecommended Dosage (per cubic yard)Residential SlabsMicrofiber0.5–1.5 lbsCommercial FloorsMacrofiber2.0–4.0 lbsPrecast ElementsMacrofiber3.0–5.0 lbsPavementsMicrofiber0.75–1.5 lbs3. Compatibility with Mix DesignEnsure fibers are compatible with admixtures and other additives. Daye’s fibers are engineered for easy integration without compromising concrete workability.Why Choose Daye’s Microfibers?Daye leverages 20+ years of manufacturing expertise to produce microfibers that ensure:
