The inconsistency between the measured temperature and the actual temperature of the laboratory rotary tube furnace may be caused by various reasons, including:
1. Temperature sensor related issues Improper sensor position Reason: If the temperature sensor is not placed in a position that can accurately reflect the average temperature inside the furnace, such as near heating elements or furnace doors where there is a large temperature gradient, it will result in a deviation between the measured temperature and the actual temperature. Example: The sensor is closely attached to the heating zone of the furnace tube, and the measured temperature is too high; If placed at the cold end of the furnace tube, the measured temperature will be too low. Sensor aging or damage Reason: Long term high temperature environment may cause sensor performance degradation or measurement distortion due to physical damage. Testing method: Use a standard thermometer for comparative measurement, or calibrate the sensor regularly. Sensor response delay Reason: The sensor’s response speed to temperature changes is insufficient, resulting in a delay in dynamic measurement compared to actual temperature changes. Impact: During rapid heating or cooling, there is a significant difference between the measured value and the actual value.
2. Thermocouple or compensation wire issues Thermocouple material mismatch Reason: The thermocouple material does not match the compensation wire material, resulting in inaccurate cold end compensation. Impact: Systematic deviation in temperature measurement. Compensation wire fault Reason: Compensation wire insulation damage, poor contact, or electromagnetic interference can cause signal transmission distortion. Testing method: Check the appearance of the wire, measure the resistance value, and eliminate electromagnetic interference sources.
3. Temperature control system issue Improper PID parameter settings Reason: PID controller parameters (proportional, integral, derivative) were not optimized, resulting in unstable or overshoot temperature control. Impact: The measured temperature fluctuates greatly and deviates significantly from the set value. Calibration deviation of temperature controller Reason: The temperature controller has not been regularly calibrated or the calibration method is incorrect, resulting in the accumulation of measurement errors. Solution: Regularly calibrate the temperature controller using a standard temperature source.
4. Furnace structure and insulation performance issues Poor sealing of furnace body Reason: The furnace door, flange and other parts are not sealed tightly, resulting in heat loss and actual temperature lower than the measured value. Detection method: Check the leakage point of the furnace body and repair the sealing components. Aging of insulation materials Reason: The performance of insulation materials has decreased, resulting in uneven temperature distribution inside the furnace and deviation between measured values and actual values. Solution: Replace the aging insulation material.
5. Operation and process setting issues Heating rate set too fast Reason: The heating rate exceeds the equipment’s capacity, causing temperature control to lag and the measured value to be out of sync with the actual value. Solution: Reasonably set the heating rate to avoid temperature overshoot. The influence of samples on temperature Reason: The heat absorption or release characteristics of the sample cause local temperature changes, which affect the measured values. Solution: Optimize the placement of samples or use multi-point measurement of average temperature.
6. Environment and interference factors electromagnetic interference Reason: The strong electromagnetic field nearby interferes with the temperature sensor signal, resulting in measurement errors. Solution: Block the sensor signal line and keep it away from interference sources. Environmental temperature changes Reason: The temperature fluctuation in the laboratory environment affects the heat dissipation of the furnace body, resulting in a deviation between the actual temperature and the measured value. Solution: Control the laboratory environment temperature or insulate the furnace body.
7. Equipment aging and maintenance issues Long term use of equipment Reason: Aging of furnace body, heating elements and other components leads to a decrease in temperature control performance. Solution: Regularly maintain the equipment and replace aging components. Improper maintenance Reason: Failure to clean, calibrate, and maintain the equipment according to regulations resulted in inaccurate temperature measurement. Solution: Establish an equipment maintenance plan and strictly implement it.
