4 Roller Plate Rolling Machine To Beijing
发表于:2026-9-11 11:23:12|本帖共 559 字 2044
       4 roller plate rolling machine to Beijing
  One Beijing customer bought 4 roller plate rolling machine from us, they have three series products: flanges and forgings; steel seamless and steel plate butt-welded pipe fittings (elbows, tees, reducers, elbows, etc.); factory configuration of pipelines. 18 kinds of materials, more than 360 specifications and models.
  Hydraulic plate rolling machine, 4 rollers, very good performance, fast work, full technical
  Basic parameters:1. Working length - 2550mm2. Rolling / pre-bending thickness - 20 / 16mm3. Upper roller diameter - 330mm4. Lower roller diameter - 310mm5. Installed power - 15kw6. Weight about 13 tons
