Valveless Plunger Pump Measurable Media
发表于:2026-9-10 11:29:16|本帖共 1,381 字 1297
       Valveless Plunger Pump Measurable Media Tested with over 200 media: This valveless plunger pump is truly "undemanding." It has handled 46# machine oil, as well as hydrochloric acid, acetone, and . It has measured a single 0.3g dose of glycerin and supported 24-hour continuous spraying of 500ml. What can it spray?
Category | Examples of Media Strong Acids & Bases: Hydrochloric acid, nitric acid, sulfuric acid, phosphoric acid, sodium hydroxide, ammonia, perchloric acid Organic Solvents: Acetone, xylene, toluene, ethyl acetate, , methanol, ethanol Oils: 46# machine oil, hydraulic oil, diesel oil, gasoline, transformer oil, silicone oil, edible oil Water: Pure water, ultrapure water, deionized water, distilled water Viscous Liquids: Glycerin, syrup, AB glue, adhesive, gelatin, protein solution, dairy products Specialty Liquids: Ink, perfume, nicotine, hyaluronic acid, electrolyte, curing agent As long as three conditions are met: no particles, no curing, and no corrosion to ceramics/PTFE—it can be stably transported. Key Parameters Specifications Parameters Single Displacement 0-0.13cc (adjustable) Minimum Dosage 0.3g/2 seconds per spray Continuous Spray 500ml per 24 hours Suitable Viscosity Water → Edible Oil Summary in One Sentence From strong acids to silicone oils, from trace amounts to continuous flow—a good pump is one that can handle any medium. If you have specific selection and quotation requirements for precision valveless plunger pumps or liquid transfer pumps, please contact CIXIFM Winny: : sales01@cxflowmeter.com WhatsApp: 008618049841995
好的,谢谢各位前辈,我先去实践一下。
2026-9-18 07:17:54|本帖共 18 字 回复
