Industrial vacuum cleaner material requirements
发表于:2026-8-31 11:05:41|本帖共 798 字 2415
       There are some requirements for the choice of materials for industrial vacuum cleaners. We can make good industrial vacuum cleaners according to these requirements.
  1. The first point is to select the material of the vacuum cleaner's chassis and dust bucket. Generally, we will use stainless steel plate or iron plate with the thickness to meet the standard.
  2, followed by the bag-type main dust compartment, in fact, it has been specially treated, so that it will not be easy to ash in the process of use, but also can effectively filter a large amount of dust.
  3. There is also a requirement for the selection of the motor of the industrial vacuum cleaner. Generally speaking, we will use a power source of 380V to ensure that it has powerful power and can work continuously for 24 hours.
  These are actually some of the requirements for the material of our industrial vacuum cleaners, and because of the satisfaction of these, we can get good results.
