Apr 14, 2026
发表于:2026-8-31 09:09:14|本帖共 4,044 字 2786
       Freezing halved plums individually is more demanding than freezing many other fruits. The product has high surface moisture, soft flesh, natural sugars, and an irregular cut profile that can affect airflow contact and freezing uniformity. In IQF processing, the cooling coil inside the blast freezer plays a major role in determining how quickly heat is removed and how well product quality is preserved.
  A properly designed blast freezer cooling coil helps processors freeze halved plums rapidly, limit clumping, maintain fruit appearance, and support stable production capacity.
  Product Challenges in IQF Halved Plum Freezing
  Halved plums behave differently from diced vegetables or firmer fruit products. Their characteristics create several engineering and process challenges during freezing:
  soft tissue can be damaged by slow freezing
  surface juice and moisture can lead to sticking
  sugar content affects freezing behavior
  uneven fruit size can reduce process uniformity
  frost load in the freezer can become significant during long runs
  Because of these conditions, the evaporator or air cooling coil in the blast freezer must be selected specifically for fruit IQF duty rather than general cold room service.
  Function of the Cooling Coil in a Blast Freezer
  The cooling coil removes heat from the circulating air inside the freezer. Fans push air across the coil, lowering the air temperature, and that cold air then passes over the halved plums on trays, belts, or conveyor surfaces.
  For IQF halved plums, the coil must support more than basic low-temperature operation. It must also help maintain:
  strong and even airflow
  low coil pressure drop
  stable freezer temperature
  manageable frost buildup
  consistent freezing across the full product bed
  This directly affects fruit separation, texture retention, and final pack quality.
  Why Coil Design Matters for Halved Plums
  If the blast freezer coil is undersized or poorly matched to the process, the result may include:
  slow freezing time
  fruit pieces sticking together
  excessive dehydration
  uneven freezing from edge to center
  high frost accumulation
  unstable air distribution
  For halved plums, fast crust freezing is especially important. A well-designed IQF freezer evaporator coil helps freeze the fruit surface quickly so the halves remain separate and retain better shape.
  Important Coil Design Features
  Low-Temperature Capacity
  The coil must deliver sufficient refrigeration duty at the required evaporating temperature. IQF fruit freezing often operates at low temperatures to shorten residence time and improve product quality.
  Suitable Fin Spacing
  Halved plums release moisture into the air stream, which increases frost formation on the coil. Fin spacing should be selected carefully to reduce blockage and extend runtime between defrost cycles.
  Efficient Airside Performance
  The airside of the coil must provide high heat transfer while keeping airflow resistance under control. This is essential for maintaining the correct air velocity through the freezer.
  Hygienic Construction
  In food processing, the cooling coil should be designed for cleaning access, proper drainage, and durable performance in wet, washdown-prone environments.
  Strong Defrost Compatibility
  IQF fruit systems often need reliable defrost control. The coil should be designed for the chosen method, such as hot gas defrost, water defrost, or electric defrost depending on freezer configuration.
  Benefits for IQF Plum Processors
  Using the correct blast freezer air cooler for halved plums can improve both product quality and plant efficiency.
  Better Product Separation
  Rapid freezing reduces the chance of fruit halves sticking together, which is critical in IQF packaging.
  Improved Appearance
  Uniform freezing helps preserve the plum's natural shape, color, and surface condition.
  Stable Throughput
  A properly selected coil supports consistent freezer performance and helps maintain target production rate.
  Reduced Frost Problems
  Optimized coil geometry and fin spacing help reduce airflow loss caused by frost buildup.
  More Reliable Operation
  When the coil matches the actual moisture load and freezing duty, the system runs more consistently over long production cycles.
  Conclusion
  A blast freezer cooling coil for IQF halved plums is a critical component in achieving fast freezing, good fruit separation, and dependable line performance. Because halved plums are delicate, moist, and sugar-rich, the coil must be designed to handle low temperatures, frost load, and uniform airflow under demanding food processing conditions.
  With the right IQF freezer coil, processors can improve frozen fruit quality, reduce sticking, and maintain efficient long-run production in plum freezing applications.
