1. Seed soaking disinfection
Hot water scalding seeds is the most commonly used and economical disinfection method, which can effectively prevent tomato leaf mold, early blight, canker and other diseases.
First put the seeds in water at 50-55 degrees Celsius, soak for 15 minutes, pay attention to all-round soaking, and stir evenly to ensure that all the seeds are heated. Then, pick it up and transfer to warm water at 25 degrees Celsius to soak for 4 hours. Pick it up again and soak it with 1000 times the potassium permanganate solution for 10-15 minutes. Potassium permanganate has strong bactericidal properties. If the soaking time is too long, it will threaten the life of the seeds, so it depends on the time to pick it up. Finally, rinse off the solution with clean water. Finally, it is placed in an environment with a temperature of 30 degrees Celsius and a humidity of more than 60%, and it will sprout in 3-4 days.
2. Seedbed soil disinfection
Using the medicament smothering method, you can use 25-30 grams of 50% carbendazim wettable powder per 1000 kg of bed soil before sowing. When treating, spray the carbendazim into an aqueous solution on the bed soil and mix well. The plastic film is tightly covered and can kill many pathogens such as fusarium wilt in the seedbed soil in 2 to 3 days. In the fumigation and sterilization method, formaldehyde, methyl bromide and other fumigation agents can be added to the seedbed soil, and the surface of the soil is covered with plastic film and other coverings to diffuse the drug gas in the bed soil to kill the germs. After the soil is fumigated, sowing is performed after the medicine is dispersed.
3. Water control
The seedling stage requires high water content. Insufficient water will lead to slow growth and root failure. Too much water will cause excessive growth and induce disease transmission. Generally, watering should be watered twice a day. Choose between 9 to 10 in the morning and around 4 in the afternoon.
4. Temperature management
The temperature is controlled at 20-25℃ during the day and 10-15℃ at night. High temperature will lead to lengthening, especially when two leaves and one heart emerge, they will grow more intensely. At the same time, it is necessary to avoid excessive changes in temperature. Excessive stress will cause tomato growth to stagnate, and heat preservation and cold protection should be done in advance.
5. Light management
Try to extend the time for seedlings to see the light, so that they can start flower bud differentiation earlier, reduce the fruit-setting nodes, and achieve the goal of premature maturity. Generally, the exposure time is 8 hours. After emergence, clean the shed film and increase light. If the light is weak, it is easy to cause excessive length. If continuous cloudy weather occurs, an incandescent lamp should be installed for supplement light. After 2 true leaves, the plug tray can be opened 10-15 cm away to facilitate ventilation and light transmission, and control the growth of small seedlings.
6. Nutrition supply
Ensure that the soil organic matter content is rich, so as to be able to provide all kinds of nutrients needed in the seedling stage. Especially after the emergence of true leaves, the seedlings will have new roots, absorb soil nutrients, and start autotrophic growth. If the soil nutrients are insufficient, the color of the seedlings' leaves will be lightened. When the symptoms of fertility appear, 50g potassium dihydrogen phosphate and 50 g urea can be added. 15 kg of water, prepared as a solution for irrigation, or sprayed with amino acid foliar fertilizer or potassium dihydrogen phosphate, foliar micro-fertilizer, etc., should be noted that the concentration should be 1/3 to 1/2 lower than the normal dosage.
Zhengzhou Delong Chemical CO., Ltd. is the production base of plant growth regulators in China, which established in 2009, specializing in offering plant protection products. If you have any question, contact us any time.
