The classification, use and characteristics of chip conveyor
发表于:2026-8-15 08:25:21|本帖共 2,180 字 1953
       Magnetic conveyor is widely used for machine tools and automatic line (not suitable for more than 100 mm long or group chip and Ductile iron used for piston ring processing), and water, oil cooling machine cooling liquid processing system to separate scraps of ferromagnetic materials important chip conveyor, in particular to deal with cast iron crumbs, scrap iron and gear machine tool exfoliation effect is better.
  Chain type chip conveyor is mainly used to collect and transport all kinds of volume, mass, block chip, and can removal the chip that magnetic chip conveyor cannot solve the chip ,such as copper, aluminum, stainless steel, carbon block, nylon and other materials, widely used in various types of CNC machine tool processing center combination machine tools and flexible production line, also can be used as stamping, cold mound machine, small parts of the conveyer, applied to health, Food production and transportation play a role in improving the operating environment to reduce labor intensity, improve the degree of automation of the whole machine, chain plate can be made according to user requirements of stainless steel and cold rolled plate two.
  Magnetic roller type chip conveyor use magnetic roller rotation, chip step by step between each magnetic roller transfer, in order to achieve the purpose of conveying chip. This machine is developed on the basis of magnetic conveyor. It makes up for magnetic conveyor in some aspects of the use of the performance and structure of the deficiency. It is suitable for conveying powdery chips in wet processing, and it is more suitable for removing chips under the condition that there are more oil stains in the chip and cutting fluid.
  Scraper chip conveyor has a wide range of transmission speed, high working efficiency, effective chip removal width diversification, can provide sufficient selection range, such as CNC machine tools, machining centers, grinders and automatic lines. In the processing of grinding metal sand, abrasive particles, and aluminum chips in the automotive industry, the scraper is equipped with special chain on both sides, scraping board height and distribution spacing can be randomly designed, so the transmission is smooth, compact structure, good strength. And according to user needs to add steel net recoil, scraping device, eddy current separator, oil-water separator and other forms of integrated filtration system to improve the surface processing accuracy of products, save coolant, reduce the labor intensity of workers, is a more widely used machine tool auxiliary device.
