GW管道式排污泵适用范围及特点
发表于:2026-2-1 10:31:42 2049
       GW管道式排污泵适用范围及特点 GW pipeline scope and merits of sewage pump 该系列无堵塞排污泵,适用于输送工业废水和城市生活污水,它的是能输送含有固体颗粒和纤维物质的污水。除输送污水外,还适用作疏水泵、纸浆泵,过滤冲洗冷凝循环泵 、灌溉用泵等。广泛适用于矿山、建筑工地、医院、宾馆、污水处理等场合。 This series of non-clogging sewage pump is suitable for transportation of industrial wastewater and urban domestic sewage, and its biggest advantage is able to transport the material containing solid particles and fibers of the sewage. In addition to conveying the sewage, but also valid for the dredging pumps, pulp pumps, filter cleaning condensate pump, irrigation pumps. Widely used in mines, construction sites, hospitals, hotels, sewage treatment and so on occasions. GW管道式排污泵主要特点 GW pipeline sewage pump main features 1、该系列的无堵塞排污泵,采用了单通道叶轮,大大提高了污物通过能力,能有效地通过泵口径5倍的纤维物质与直径为泵口径50%的固体颗粒。 1, the series of non-clogging sewage pump, using single-channel impeller, greatly increased the dirt, through capacity, and can effectively through the pump five times the diameter of the fiber material and a diameter of pump bore 50% of the solid particles. 2、 机械密封采用国际上型的硬质耐腐碳化钨材料制成,有效地延长了水泵的使用寿命。 2, mechanical seal using the latest models of the international hard corrosion-resistant tungsten carbide material, which effectively extends the life of the pump. 3、GW型管道式无堵塞排污泵的进出口法兰在同一条水平线上,以管道形式安装,泵体配有安装底座,使用极为方便。使用介质温度不超过80℃。 3, GW-type pipe-type non-clogging sewage pump flange on the same level of import and export lines, to pipe the form of installation, with pump installed base, very convenient to use. The use of medium temperature does not exceed 80 ℃. 4、LW型直立式无堵塞排污泵,是直立型排污泵,泵体配有底脚架,从脚架下面吸入,从电机下端的泵体中间排出,即可移动,亦可固定安装使用。使用介质温度不超过80℃。 4, LW-type vertical non-clogging sewage pump is a vertical-type sewage pump, pump equipped with bottom tripod, from the tripod following inhalation, from the electrical discharge between the bottom of the pump, you can move, can be a fixed installation. The use of medium temperature does not exceed 80 ℃.
谢谢分享,帮大忙了
2026-2-24 12:37:53 回复
思路清晰
2026-5-4 02:05:33 回复
2026-5-22 15:28:03 回复
