(1) Mining Industry
During the mining and beneficiation processes, it is necessary to transport media such as ore pulp, tailings, and concentrates that contain a large number of hard particles. Aluminum oxide ceramic lined pipes can effectively resist the wear of these particles, extend the service life of the pipes, and reduce maintenance costs. For instance, in the tailings transportation systems of iron, copper, and gold mines, aluminum oxide ceramic lined pipes have been widely applied and achieved excellent results.
(2) Chemical Industry
In chemical production, it is often necessary to transport corrosive media such as acids, alkalis, and salts, as well as slurries containing solid particles. The corrosion resistance and wear resistance of alumina ceramic lined pipes make them an ideal choice for chemical pipelines. In fields such as fertilizers, pesticides, pharmaceuticals, and petrochemicals, alumina ceramic lined pipes are used to transport various corrosive media and slurries, ensuring the safety and stability of production.
(3) Power Industry
In thermal power plants, it is necessary to transport pulverized coal, fly ash, slag and other materials. These materials have high hardness and flow rate, causing severe wear to the pipelines. The alumina ceramic lined pipes can withstand the high-speed erosion of pulverized coal and high-temperature environment, significantly increasing the service life of the pipes and reducing the frequency of shutdowns for maintenance due to pipe wear. Meanwhile, in the steam-water pipeline system of thermal power plants, the corrosion resistance of alumina ceramic lined pipes can effectively prevent pipe corrosion and leakage.
(4) Metallurgical Industry
During the metallurgical production process, it is necessary to transport high-temperature and highly abrasive media such as ores, slags, and molten iron. The high-temperature resistance and wear resistance of alumina ceramic-lined pipes make them capable of meeting the special working conditions of the metallurgical industry. In metallurgical enterprises such as steel mills, aluminum plants, and copper plants, alumina ceramic-lined pipes are widely used in material conveying systems, improving production efficiency and reducing costs.
(5) Other Industries
In addition to the above-mentioned industries, alumina ceramic lined pipes have also been applied in the building materials, environmental protection, food and other industries. For instance, in the cement conveying system of the building materials industry, alumina ceramic lined pipes can resist the wear of cement particles; in the sewage treatment system of the environmental protection industry, the corrosion resistance of alumina ceramic lined pipes can effectively handle various sewage; in the material conveying system of the food industry, the smooth surface and hygienic performance of alumina ceramic lined pipes meet the food-grade requirements.
Alumina ceramic lined pipes, with their outstanding wear resistance, corrosion resistance, high-temperature resistance and smooth surface, have become an efficient solution to pipe wear problems. They can significantly extend the service life of pipes, reduce maintenance costs, enhance production efficiency, and ensure the stability and economy of industrial production. With the continuous development of industrial technology, the requirements for pipe performance are getting higher and higher. Alumina ceramic lined pipes will be widely applied in more industries and fields, making greater contributions to industrial production.
