08.Apr.2014 Maintenance-free, highly accurate, compact CO2 Sensor Module designed for OEM Applications
发表于:2026-10-18 08:24:34|本帖共 417 字 4714
       The dual wavelength NDIR measuring principle is maintenance free and highly insensitive to environmental influences. Aging effects are automatically compensated.
  The multiple point CO2 and temperature adjustment ensures excellent accuracy over the entire temperature working range. The CO2 measurements with a measuring range up to 10,000 ppm are available on the digital E2 interface. The measurement interval can be set individually according to the requirements of the application.
