Oil filter press machine is ready for shipping
发表于:2026-9-28 13:10:17|本帖共 416 字 653
       The 200kg/h oil filter machine 6LB-350 has been completed and packaged in wooden box for shipping.
  This edible oil filter machine uses gear pump as power to convey the oil from the oil press to the plate filter filter.The edible oil through the filter cloth to filter. Clean oil flows through each copper valve to the stainless steel oil tank below, completing the filtration process.
  Our Vic Machinery also has other models of oil filtration equipment, can also be customized, welcome to purchase!
