HZIRPD640 Intelligent Visual Partial Discharge Infrared Multifunctional Live-Line Detector
发表于:2026-9-24 12:43:49|本帖共 3,054 字 90
       Overview
  This product is suitable for partial discharge and temperature anomaly detection and location operations of high-voltage electrical equipment such as switchgear and overhead lines without power interruption. It is a multi-functional detection instrument that integrates acoustic imaging and infrared thermal imaging.
  The acoustic imaging module, equipped with a 128- channel microphone array and a visible light camera, can display partial discharge intensity, discharge frequency, discharge point location, real-time waveform graphs, and spectrum graphs. The thermal imaging module, equipped with a high-resolution infrared camera, can accurately display the surface temperature distribution of equipment, showing the highest and lowest temperature values, and tracking high and low temperature points in real time. This multi-functional detector can perform comprehensive condition detection and diagnosis of operating electrical equipment, including appearance, temperature anomalies, and partial discharge faults. It improves the efficiency of electrical equipment inspection, meets the practical needs of engineering testing, and has high engineering application value.
  Performance Characteristics
  The device is equipped with both acoustic and thermal imaging systems, enabling precise location of partial discharge and local overheating through imaging.
  The acoustic imaging system is equipped with a 1080P high-definition camera and a 128-channel microphone array, which automatically captures the discharge location and can display real-time waveforms, spectrum diagrams, PRPD diagrams, etc.
  The infrared imaging uses a 640*512 high-resolution infrared thermal imaging sensor, which can display the highest and lowest temperature values and track them in real time.
  It features a 1920*1080 resolution OLED high-brightness display with a scroll wheel for backlight adjustment, ensuring clear visibility even in bright sunlight. The touchscreen and shortcut keys make it simple and convenient to use.
  It is equipped with a removable, high-capacity lithium-ion battery, with a single cell providing approximately 3.5 hours of battery life.
  The one-click recording/photo-taking function stores videos and images on the local device by default. It supports one-click generation of test report templates from images and supports data export to USB flash drives for easy access and viewing on other devices.
  It has Bluetooth and WIFI communication hardware modules, which can easily connect to the Internet or upload data by installing corresponding software.
  It has an expandable external USB interface, which can be used to expand the range of mice, keyboards, storage media, etc. for batch data management.
  Technical Indicators
  Overall technical specifications:
  Operating System: Linux
  16.8V / 3000mAh per cell , three cells in total
  Battery life: Full charge takes 1.5 hours; single battery lasts for 3.5 hours.
  monitor: 7-inch OLED display
  External dimensions: 245mm*145mm*70mm (excluding infrared camera)
  weight: 1.2kg (1.55kg with battery and infrared camera)
  Infrared imaging technical specifications:
  Resolution : 640* 512
  Focusing method: Fixed focus
  Temperature measurement range: -20℃~150℃
  Temperature measurement accuracy: @5m ±(2%±2℃)
  Acoustic imaging technical specifications:
  Number of acoustic channels : 128
  Detection frequency band: 1kHz~70kHz
  Array diameter: 11 0 mm
  Discharge intensity range: 0μV~8000μV
  Discharge decibel range: 0dB~78dB
  Video format: 1 080P@20 fs
