食品品质可视化:利用多光谱成像的深紫外荧光传感技术检测和监测绿叶层上的食源性病原体
发表于:2026-9-23 08:44:08|本帖共 3,198 字 2635
       对可持续和安全的农产品原材料的需求正在迅速增长。降低与新鲜农产品相关的食源性疾病风险是行业和学术研究人员多年来一直在努力解决的一项任务。迫切需要设计一种非侵入性光学检测系统来监测叶片表面的食源性病原体。用于评估病原体定植的侵入性技术,在叶菜产品上检测食源性病原体往往滞后的。深紫外荧光(DUVF)传感和可见-近红外多光谱成像(MSI)以前曾被用于监测植物对生物和非生物胁迫的相互作用。使用我们开发的病理系统用于监测在莴苣/菠菜等绿叶蔬菜中入侵的沙门氏菌和李斯特菌,研究表明,沙门氏菌/李斯特菌处理后,植物对叶绿素色素波动的反应迅速。研究还表明,通过叶面或根部补充沙门氏菌/李斯特菌的施用模式会改变ChlA反应。数据还显示,植物早期光合反应的哨兵反应可能对检测绿叶蔬菜上的食源性病原体至关重要。MSI表明,植物胁迫是可检测的,并且与植物上的细菌接种率成比例。研究可能会提供更好的实施策略和技术,以提高产量并降低与食源性细菌病原体污染相关的风险。
  Deep ultraviolet fluorescence sensing with multispectral imaging to detect and monitor food-borne pathogens on the leafy green phyllosphere
  Abstract
  Demand for sustainable and safe raw agricultural commodities is growing rapidly worldwide. Reducing the risk of foodborne illnesses associated with fresh produce is a task which the industry and academic researchers have been struggling with for many years. There is an immediate need to devise a non-invasive optical detection system to monitor the food-borne pathogens on the leaf surface. The detection of foodborne pathogens on leafy produce is performed often too late because of the invasive techniques used to evaluate the pathogen colonization. Use of deep ultraviolet fluorescence (DUVF) sensing and visible–near infrared multispectral imaging (MSI) has previously been used to monitor plant interactions against both biotic and abiotic stress regimes. Using the patho-system that we developed to monitor Salmonella sp. and Listeria sp. ingression in leafy greens such as lettuce/spinach, we show that plant response in terms of fluctuation of chlorophyll pigments post-Salmonella/Listeria treatment is rapid. We also show that the mode of application of Salmonella/Listeria via foliar or root supplementation changes the ChlA response. Our data also reveals that the plant sentinel response in terms of early photosynthetic response may be critical to detect food-borne pathogens on leafy greens. MSI demonstrated that plant stress was detectable and proportional to the bacterial inoculation rate on plants. Our research may lead to implementation of better strategies and technology to increase yield and reduce risks associated with contamination of foodborne bacterial pathogens.
  Each plant was imaged once with the VideometerLab® 4 at each time point and three times.The VideometerLab® 4 (VL4) can gather foliar spectral images needed
  相关阅读
  丹麦Videometer Liq固/液体稳定性分析仪检测仪
  丹麦VideometerSLS/SGT颗粒/粘度/口感评价测量仪
  丹麦videometer多光谱颜色/质构/成分综合分析仪
  食品品质光谱成像可视化:应用多光谱成像的黄油曲奇质量评估
  食品品质光谱成像可视化:光谱成像应用于面食小麦籽粒真伪检测的可行性研究
  食品品质光谱成像可视化:多光谱成像 (MSI):一种检测掺有马肉的碎牛肉的有前景的方法
  食品品质光谱成像可视化:色度计和多光谱图像的肉类颜色测量结果的比较
  食品品质光谱成像可视化:蔬菜的多光谱成像
  食品品质光谱成像可视化:利用多光谱成像进行非侵入性污染评估和肉类样品绘图
  食品品质光谱成像可视化:使用多光谱成像分析快速无损识别注水牛肉样品
  食品品质光谱成像可视化:具有不同亚硝酸盐和硝酸盐还原酶活性的肉相关葡萄球菌在发酵香肠中的颜色形成
  食品品质光谱成像可视化:虾在冰成熟过程中的可剥性和质量变化
  食品品质光谱可视化研究:长时间低温热处理的奶牛和公牛的肉韧性与结缔组织特性的关系
  食品品质光谱成像可视化:使用 vis/NIR 多光谱成像对微加工苹果的每日新鲜度衰减:初步测试
  食品品质光谱成像可视化:多光谱视觉系统与色度计在肉色评估中的比较
  食品品质光谱成像可视化:肉品连续煎炸多维质量监控新视觉技术
  食品品质光谱可视化研究:使用光谱成像和三色测量对鲑鱼虾青素颜色进行分类
  食品品质光谱可视化研究:虾青素涂层分类的多光谱图像分析
  食品品质光谱可视化研究:高通量多光谱图像处理在食品科学中的应用
  食品品质光谱可视化研究:一种基于多光谱图像的肉类检测智能决策支持系统
  食品品质光谱可视化研究:多光谱成像在草莓果实品质属性和成熟期测定中的应用
  食品品质光谱可视化:多光谱成像技术在阿拉比卡和罗布斯塔咖啡豆鉴别中的应用
  多光谱食品品质无损检测:用于快速评估鸡肉汉堡微生物质量的光谱数据
  多光谱食品品质分析:利用基于光谱学、成像分析和模拟人类感官的传感器技术快速评估食用海藻的微生物质量霉菌种类和代谢物
  多光谱食品品质可视化研究:结合DNA条形码、靶向代谢物分析和多光谱成像来识别切片面包中的霉菌种类和代谢物
  多光谱食品品质可视化:通过光谱和仿生传感器和数据融合评估腌制鸡肉Souvlaki的微生物破坏和质量
  多光谱食品品质可视化:凝乳酪蛋白凝胶性质对马苏里拉干酪挤压结构、流变学和功能性质的影响
  多光谱食品品质可视化:基于双道二维相关光谱(2t2d Cos)和多快照可见近红外多光谱成像的牛肉肌肉鉴别新方法
  多光谱食品品质可视化:丹麦黄油曲奇的分批与连续面团混合-近红外高光谱成像研究
  多光谱食品品质可视化:利用透射多光谱成像技术定量评价椰子油掺假
